# Contributing a New Recipe
This page explains how to contribute a new **Cookbook-Recipe** to PyLabRobot.
It is assumed you are already familiar with the general contributor workflow as outlined in the Contributor Guide (see [Contributing to PyLabRobot](contributing.md)).
## 1. Where to add the Recipe
1. Fork the repository and clone to your local machine, as per the usual workflow.
2. Navigate to your fork's documentation directory: `pylabrobot/docs/cookbook/recipes/`
3. Create a new Jupyter Notebook (recommended) for your recipe. For example:
`star_movement_plate_to_alpaqua_core.ipynb`
4. Ensure the notebook is self-contained (includes code, narrative, images, and outputs) and follows the style of existing recipes.
## 2. Adding a Recipe Card to the Cookbook Page
Once your recipe notebook is ready and committed to `docs/cookbook/`, you must add an entry to the `pylabrobot/docs/cookbook/index.rst` file so that the recipe shows up on the website.
Add something like the following:
```rst
.. plrcard::
:header: Move plate to Alpaqua magnet using CORE grippers
:card_description:
- Resource movement using CORE grippers
- Resource position check using grippers
- PLR autocorrection of plate placement onto PlateAdapter/magnet
:link: star_movement_plate_to_alpaqua_core.html
:tags: ResourceMovement PlateAdapter HamiltonSTAR
Then, further down in the same index.rst, add the TOC reference:
```rst
.. Page TOC
.. toctree::
:maxdepth: 2
:hidden:
recipes/star_movement_plate_to_alpaqua_core
Replace `star_movement_plate_to_alpaqua_core` with your recipe’s base name.
## 3. Adding New Tags (Optional)
**Tags** categorize Cookbook recipes by topic, device, or feature.
They populate the filter buttons at the top of the Cookbook page, helping users quickly find related content - for example:
- `ResourceMovement` (type of operation)
- `HamiltonSTAR` (robot platform)
- `PlateAdapter` (PLR resource type)
If your recipe introduces a **new tag** (for example, `MagneticSeparation`), follow these steps:
1. Add the new tag to the `:tags:` line in your `plrcard` above.
2. Open `pylabrobot/docs/_templates/plr_card_grid.html` and add a new filter button, for example:
```html
Magnetic Separation
This ensures your new tag appears as a filterable button on the Cookbook cards grid.
## 4. Checklist Before Submitting Your Pull Request
- The new notebook is located in `docs/cookbook/recipes/`.
- You added a `plrcard` entry and a `toctree` reference to `index.rst`.
- Any new tags are added to `plr_card_grid.html`.
- Documentation builds without errors (`make docs`).
- The notebook executes cleanly from start to finish.
- PR title and description clearly describe your new recipe.
- Linting, formatting, and typing checks pass:
```bash
make lint
make format-check
make typecheck
- Tests run successfully and coverage is unaffected.
## 5. Example Pull Request
Example PR: [PR#726 Start PLR Cookbook](https://github.com/PyLabRobot/pylabrobot/pull/726/)
- Suppose you are adding the recipe file `star_movement_plate_to_alpaqua_core.ipynb`.
- Your PR would contain:
- the recipe notebook: `docs/cookbook/recipes/star_movement_plate_to_alpaqua_core.ipynb`
- Modifications to `docs/cookbook/index.rst` adding the card and TOC entry.
- If relevant: Modification to `docs/_templates/plr_card_grid.html` to add new tag(s).
- In the PR description mention something like: *“Add new Cookbook recipe: Move plate to Alpaqua magnet using CORE grippers (resources movement, gripper position check, placement correction).”*
- Link to any relevant issue or discussion for context.
## 6. Style Tips for Cookbook Recipes
- **Write clearly and narratively** – start with the recipe’s goal, list prerequisites (hardware, deck layout, robot backend), and describe the expected outcome.
- **Combine code and explanation** – keep code cells short and follow them with brief commentary rather than large, unannotated blocks.
- **Include visuals** – add static screenshots for deck layouts and optional GIF or MP4 animations to show motion or results.
- **Use consistent section headings** – for example: *Prerequisites*, *Protocol Mode*, *Setup*, *Execution*, and *Variations*.
- **Ensure smooth execution** – notebooks must run cleanly from start to finish without errors or manual input.
- **Always include a simulation run** - recipes must support `protocol_mode == "simulation"` to allow a complete *in silico* execution of the automated protocol (aP) without errors, and remain valid when executed on actual hardware.
- **Keep language accessible** – avoid hardware-specific jargon without context. Even if a recipe targets a particular machine (for example, `HamiltonSTAR`), write so readers unfamiliar with that platform can follow the logic.
- **Be explicit about external dependencies** – if a recipe relies on components outside PyLabRobot (for example, third-party Python libraries, SDKs, or local data files), **document this clearly** in the *Prerequisites* section.
- **Make recipes concise and complete** – each should be self-contained and reproducible, demonstrating a full automation concept without hidden dependencies.
## 7. Questions & Support
For questions, feedback, or collaboration on Cookbook recipes - including structure, formatting, or contribution workflow -
visit the community forum at [discuss.pylabrobot.org](https://discuss.pylabrobot.org).
Thank you for helping expand the PyLabRobot Cookbook - concise, self-contained, and well-documented recipes are invaluable for both human developers and AI systems.
They illustrate how to write complete, reproducible automation protocols and form the foundation for AI-assisted protocol generation.
