# Writing PyLabRobot Device Drivers & Hello-World Guides How to add a device driver and its hello-world notebook, for humans and agents. This guide covers device-specific requirements; follow the [general contribution guide](contributing.md) for shared code style, testing, and contribution conventions. Post on the [PyLabRobot forum](https://discuss.pylabrobot.org) before starting to avoid duplicated effort and get support. ## 1. Understand the device Recover the protocol before writing code. - **Extract, don't guess.** Work from an authoritative source — firmware/protocol docs, manufacturer log files, or a reference binary. Capture the *complete* set of command frames, error codes, status values, and exact message text, filled with real values, not placeholders. - **Get the wire format byte-exact:** transport (serial params / USB endpoint / socket), framing (delimiters, length fields, checksums), handshake (echo? ack? busy→ok?). - **Note blocking vs non-blocking commands** and how faults (e-stop, jam) surface. ## 2. Structure the driver Keep it small and idiomatic to PyLabRobot. - **One file, one plain class.** The old Driver/Backend split and capability machinery are deprecated — don't use them. Instead write a single plain class whose public methods are the device's operations, talking to hardware through a `pylabrobot.io` transport. Path `pylabrobot//.py`, re-exported from `__init__.py`. Promote to a `/` package only when it genuinely helps — a distinct subsystem, the protocol/framing layer, or a large command table — not by reflex. - **Model the device's real objects.** When the hardware has distinct addressable parts — a shaker's daisy-chained nests, a gripper's arm, a multi-channel head — give them their own classes or objects so `nest[2].shake(...)` reads like the machine works. Let the physical layout guide the object model where it makes sense; don't invent a class hierarchy the device doesn't have. A one-part device stays one class. - **Keep the logic client-side, in PLR.** Do as much control as possible from PLR rather than delegating to the device's firmware. When the hardware exposes both a canned high-level feature and the lower-level primitives it's built from, prefer driving the primitives so the sequencing, state, and decisions live in readable Python you can inspect and adapt — not in an opaque on-device routine. Reach for a firmware macro only when the primitives genuinely aren't exposed or the timing must be enforced on-device. - **Stay OS-agnostic:** no OS-specific libraries or DLLs. Running on Windows, Mac, and Linux is what keeps experiments portable and reproducible. - **Use `pylabrobot.io` for all device communication.** Use the appropriate PyLabRobot transport (`USB`, `Serial`, `FTDI`, `HID`, `Socket`, etc.) instead of calling PyUSB, pyserial, hidapi, raw sockets, vendor DLLs, or OS APIs directly from a device driver. If a required transport capability is missing, add it to `pylabrobot.io` rather than bypassing the abstraction. - **Async `setup()` / `stop()`** plus public operation methods over those `pylabrobot.io` transport primitives. - **Leave the device in the state you found it at each lifecycle boundary.** Restore changes made for a `setup()` / `stop()` lifecycle in `stop()`, and restore per-command changes before the command finishes. If the driver needs to modify device memory, registers, or configuration, read and save the original values first and restore those exact values at the end of the relevant scope, not assumed defaults. Ensure cleanup also runs on errors and cancellation, including partial setup failures. - **Log important device events.** Define a module logger with `logger = logging.getLogger(__name__)` and use it for meaningful lifecycle events, operations, state changes, recoveries, and faults. Use the appropriate log level and structured `%`-style arguments; don't use `print()` for runtime status. - **Prefer string `Literal[...]` over enums**, especially anything user-facing. A `Literal["standard", "head", "pump"]` argument plus an internal dict mapping to wire codes reads better at the call site than an enum import. `IntEnum` is fine in narrow internal cases (e.g. a fixed set of wire/register codes never exposed to callers). - **API docs:** add `docs/api/pylabrobot..rst` plus a line in `docs/api/pylabrobot.rst`. ### Share nothing between device drivers Each driver stands alone: one device's package never imports another's. What more than one device needs goes in `pylabrobot.lib`, which imports no device and nothing from `pylabrobot.legacy`: - **`pylabrobot.lib.liquid_handling`** plans pipetting for any multi-channel pipette device: where channels go inside a container (`channel_positioning.compute_channel_offsets`) and which channels can reach their targets in one X/Y move (`pipette_batch_scheduling.plan_batches`). It is pure and synchronous. The device supplies its per-channel minimum spacing and executes the plan with its own moves; `hamilton/prep/driver/features/pipettes_tests.py` and `hamilton/star/driver/features/pipettes_tests.py` show the pattern. ### Idempotent public API The public surface must expose **no non-idempotent commands.** If the hardware only offers a raw toggle/flip, keep it private (`_toggle_x`) and expose move-to-state methods (`move_x_out` / `move_x_in`) that read current state, act only if needed, then confirm. This keeps the API safe to call repeatedly — the caller states intent ("be open"), not a blind toggle. Keep connection, calibration, and state on the device; pass operation-specific settings (plate geometry, grip, offsets, speed, duration) as method arguments without carrying them between calls. ### Unverified drivers If the driver hasn't been checked against real hardware, say so loudly: `setup()` should `logger.warning(...)` that it's untested and invite a change once someone verifies it. Don't quietly present untested code as ready. ## 3. Hello-world notebook Every device ships a runnable notebook that takes a user from cabling to first command. Path `docs/user_guide///hello-world.ipynb`; wire it in via the `/index.md` `{toctree}` and add `/index` to the Manufacturers `{toctree}` in `docs/user_guide/index.md` (alphabetical). Sections (markdown cell then code cell): (1) title + property table + untested-warning; (2) how it talks — brief, since users care about the machine, not the wire; (3) physical setup; (4) `setup()`; (5) one section per operation. Cell rules: - **One concept per code cell.** If a physical action happens between steps, that's two cells: `move_tray_out()` → place plate → `move_tray_in()`. Every code cell gets a preceding markdown cell. - **Notebook JSON:** edit with a notebook-aware tool (plain-text replace is blocked on `.ipynb`); code cells `execution_count: null`, empty `outputs`; `nbformat: 4`, `nbformat_minor: 5`; every cell has an `id`; validate it parses. ## 4. Register the device and its guide Add or update the device's object in `docs/_static/devices.json` in the same change. Follow the [device registry guide](device-registry.md) for the schema. A driver and hello-world change is not complete until its registry entry has: - `api`, `api_version`, and `code_slug` pointing to the driver; - `doc_slug` pointing to the hello-world notebook, relative to `docs/user_guide/` and without `.ipynb`; and - an `id` matching the notebook's `{device-card}` directive. When the device is already registered, edit its existing object instead of adding a duplicate. In particular, add `doc_slug` when a guide is added to a device that previously had no documentation page. ## 5. Verify the integration - Test framing, parsing, command sequencing, status handling, and error handling through a mocked or captured transport without connecting to hardware. - Validate the hello-world notebook structure and imports without executing its hardware cells. - Run the device-registry tests and build the documentation so its API, code, and documentation links are checked. - Keep the unverified-driver warning until the implementation has been checked on the real device.
