# EventBus Contributor Guide This guide defines the implementation contract for contributors instrumenting a PLR frontend or driver. For subscription, event consumption, and the current frontend coverage, see the [user EventBus guide](../user_guide/machine-agnostic-features/event-bus.md). The EventBus is intentionally in-process and synchronous. It is an observation mechanism, not a control mechanism: listener failures must never affect hardware control flow. ## When to emit events Instrument **semantic public operations**: an operation that a protocol author would recognize as one action, such as fetching a plate, aspirating, shaking, or moving an arm to a location. Do not represent every serial, USB, transport, or firmware command as a *semantic* operation. The current EventBus also supports a separate diagnostic layer. Instrumented transports emit `io.read` and `io.write`, and the Hamilton USB transport emits `firmware.command.started`, `.completed`, and `.failed`. Semantic and diagnostic events are complementary: semantic events describe PLR-level operations, while diagnostic events describe the transport and controller activity performed to execute them. An instrumented method remains a no-op with respect to events unless an EventBus with at least one subscriber is active. Use one of these helpers: - `@evented_operation(...)` for a trivial projection of one public async method's invocation. - `with event_operation(...):` for explicit semantic context assembled inside an operation. - `emit_event(...)` only for a meaningful state transition that is not an operation lifecycle. Use a low-level diagnostic event only when the transport boundary itself is useful to observe. Diagnostic events may inherit the enclosing semantic operation context, but do not define a new protocol-level action or resource-transfer meaning. ## Choosing an instrumentation style Prefer explicit `event_operation()` construction for new semantic frontend operations. It keeps the event boundary and metadata next to the code that determines their meaning: ```python async def move_to_target(self, requested_target: str) -> None: target = self.resolve_target(requested_target) target_coordinate = self.coordinate_for_target(target) with event_operation( "plate_mover.move_to_target", device=resource_reference(self), resources=[], requested_target=requested_target, target=target, target_coordinate=coordinate_reference(target_coordinate), ): await self.backend.move_to(target_coordinate) ``` Compute metadata before entering the operation scope when doing so has no hardware side effects. Perform operation validation inside the scope when validation failures are part of the operation's lifecycle. Always enter the scope before issuing hardware commands so command failures emit the correlated `.failed` event. If meaningful data is known only after successful execution, expose it with `completed_data_factory`; return the full completed-event payload, including stable invocation context: ```python operation_data = { "device": resource_reference(self), "resources": [resource_reference(plate)], } completion_data: dict[str, object] = {} with event_operation( "reader.read_plate", **operation_data, completed_data_factory=lambda: {**operation_data, **completion_data}, ): result = await self.backend.read_plate(plate) completion_data["result"] = result ``` The completion factory runs after the operation body has succeeded. Keep it pure, deterministic, and non-throwing so event construction cannot turn a successful hardware operation into an application failure. `@evented_operation(...)` remains appropriate when all event metadata is a simple, pure projection of invocation arguments and pre-operation resource state. Its context factory is called with the method's original `*args` and `**kwargs`; the decorator does not inspect, bind, normalize, or apply defaults to the call. The context factory must therefore mirror the decorated method's calling signature, including positional order, parameter kinds, defaults, and `**backend_kwargs`: ```python def _set_temperature_event_context( self: "TemperatureController", temperature: float, passive: bool = False, ) -> dict[str, object]: return { "device": resource_reference(self), "resources": [] if self.resource is None else [resource_reference(self.resource)], "target_temperature": temperature, "passive": passive, } @evented_operation("temperature_controller.set_temperature", _set_temperature_event_context) async def set_temperature( self, temperature: float, passive: bool = False, ) -> None: ... ``` Do not use a decorator context factory when event meaning depends on validation, normalization, resolved targets, derived values, hardware responses, or final resource state. Construct the event explicitly inside the operation instead. In either style, context construction must be pure: it must not command hardware, mutate resource state, or perform expensive I/O. ## Event contract A `PLREvent` always contains: ```python { "sequence": 42, "name": "liquid_handler.aspirate.completed", "timestamp": "2026-08-10T12:34:56.789012+00:00", "context": {...}, "data": {...}, } ``` Use names in this form: ```text .. ``` Examples from the current implementation: ```text incubator.fetch_plate.started liquid_handler.resource_pickup.completed liquid_handler.tip_pickup.failed shaker.shake.completed temperature_controller.wait_for_temperature.completed precise_flex.move_through_cartesian_poses.completed ``` Every operation scope emits exactly one correlated lifecycle sequence: ```text .started -> .completed .started -> .failed ``` The EventBus adds these values to `context` for every lifecycle event: - `operation`: `.` - `operation_id`: a UUID shared by the lifecycle sequence Callers may add higher-level execution context with `event_context(...)`; for example, a batch identifier or protocol run identifier. Device code must not invent protocol-specific context. ## Required fields for semantic device operations Every instrumented hardware operation should provide: - `device`: the identity of the device or controller issuing the operation. Use `resource_reference()` when the frontend is a PLR `Resource`. For a frontend that is not a resource, use `device_reference()` with an explicit stable name or provide an equally typed, frontend-specific device reference. - `resources`: direct PLR resources acted on by the operation, represented with `resource_reference()`. `resources` describes the literal object operated on. Do not replace a `Well` with its owning `Plate`, or a `TipSpot` with its parent `TipRack`, merely for a downstream display. The reference includes `ancestors` so a consumer can make that presentation choice without changing the event's meaning. Use `source` and `destination` only when the operation genuinely transfers a resource between physical locations. Represent a resource endpoint with `resource_reference()`. Use `coordinate_reference()` for a geometric endpoint when no PLR resource exists. It preserves the underlying object's PLR serialization contract, including `Coordinate.type`. Avoid adding fields solely to simplify one consumer. An event should describe what the PLR API actually did; dashboards, logs, and integrations can derive their own views from the structured references. ## Canonical operation schemas The [Event Schema Registry](event-schemas.md) defines the canonical operation names, fields, units, lifecycle-specific payloads, and resource semantics for every currently instrumented frontend and diagnostic producer. Use an existing schema whenever the operation meaning matches. If a contribution introduces a genuinely new device or operation family, choose semantically accurate conventions, add the proposed contract to the registry in the same contribution, and treat maintainer review as establishing the standard for future implementations of that operation. Do not create an undocumented vendor-local alias for an existing concept. ### Manual operator actions Manual operations use `manual_operator.` so the event records both the manual executor and the semantic work requested. Represent the `ManualOperator` as `device`, list any direct modeled resources in `resources`, and preserve action-specific request data without substituting inferred deck resources. When an automated counterpart defines canonical parameter names and units, reuse them inside the manual operation's `details`. A genuine manual resource transfer additionally includes its actual `source` and `destination` resource references. ```python { "device": device_reference(manual_operator, name=manual_operator.name), "resources": [resource_reference(plate)], "manual_action": "centrifuge.spin", "title": "Spin sample plate", "details": { "relative_centrifugal_force": 300, "duration": 180, }, } ``` Operator cancellation or a provider-reported failure is a failed lifecycle outcome. Completion metadata such as `confirmed_by` belongs only on the `.completed` event. ## Failure events A failed operation retains the original invocation context and adds: ```python { "error_type": type(error).__name__, "error_message": str(error), } ``` Do not swallow or transform the original exception merely to emit an event. The EventBus emits the `.failed` event and re-raises the same failure. Add structured device-specific error details only when they are stable and useful independently of the raw message. ## Contributor checklist When adding EventBus support to a frontend or driver: 1. Choose public semantic operation boundaries; do not decorate transport primitives by default. 2. Use a stable `.` name and one event scope per logical action. 3. Prefer explicit `event_operation()` construction, especially when context includes validated, normalized, resolved, derived, measured, or final-state values. 4. Use `@evented_operation(...)` only for a trivial invocation projection. Match the context factory's complete calling signature to the decorated method; the decorator forwards the original `*args` and `**kwargs` without binding or normalization. 5. Include `device` and direct `resources` in the operation context. 6. Preserve PLR resource semantics; use ancestry for context rather than substituting resources. 7. Use PLR's default units without repeating them in field names. Add a suffix only when a value deliberately uses a different unit or representation, such as `speed_rpm` or `speed_pct`. 8. Include `source` and `destination` only for actual resource transfers. 9. Add tests for `.started`, `.completed`, and `.failed`, including operation-ID correlation. For decorated methods, test both positional and keyword invocation when the public method supports both. 10. Verify no EventBus listener is required for normal device operation and that listener failures cannot alter hardware control flow. 11. Update the [Event Schema Registry](event-schemas.md) and user-guide implementation matrix when adding a new operation, changing a payload, or instrumenting a new frontend. New or existing drivers should adopt these conventions incrementally at their public semantic API boundaries. A new operation family establishes precedent for future devices, so its schema should be reviewed as deliberately as its implementation.
