# Adding Support for a New Machine of an Existing Type This guide explains how to add support for a new machine of an existing type. For example, if you want to add support for a new liquid handler, you should read this guide. If you want to add support for a new type of machine, you should read {doc}`this guide ` first. The machine types that are currently can be found [here](/user_guide/machines). Two documents that you can read before you start are: - [Contributing to PyLabRobot](contributing.md): This document contains general information about contributing to PyLabRobot, and covers things like installation and testing. - [How to Open Source](how-to-open-source.md): This document contains step-by-step instructions for contributing to an open source project. It is not specific to PyLabRobot, and serves as a reference. Thank you for contributing to PyLabRobot! ## Background Backends are minimal classes that are responsible for communicating with a machine and are thus specific to one machine. Frontends are higher level classes that are responsible for orchestrating higher-level state and providing nice interfaces to users, and should work with any machine. For example, the STAR liquid handler backend is responsible for executing the liquid handling operations on a Hamilton STAR, while the LiquidHandler frontend is responsible for making sure a requested operation is valid given the current state of the deck. Backends should contain minimal state. We prefer to manage the state in the frontend, because this allows us to share the code across all machines of a type. For example, the liquid handler backend does not contain any information about the deck, because this is managed by the frontend. If a certain machine has a specific state that needs to be managed, like whether the gripper arm is parked on a liquid handling robot, that should be done by the backend because it is specific to the machine. ## 0. Get in touch Please make a post on [the PyLabRobot Development forum](https://discuss.pylabrobot.org) to let us know what you are working on. This will help you avoid duplicating work, and it is also a good place to get support. ## 1. Creating a new concrete backend class It is easiest to start by copying the abstract base class for the machine type to a new file. You will find this in `backend.py` in the module for the machine type. For example, the liquid handling abstract base class is located at `pylabrobot.liquid_handling.backends.backend`. You should copy this file to a new file called `.py` in the same directory. For example, the liquid handling backend for the Hamilton STAR is located at `pylabrobot.liquid_handling.backends.hamilton.STAR`. ## 2. Implementing the abstract methods The abstract base class contains a number of abstract methods. These are the methods that are expected to be implemented by the concrete backend. You should implement these methods in the concrete backend. You can use the abstract base class as a reference for what the methods should do. PyLabRobot aims to be OS-agnostic, meaning that it should work on Windows, Mac, and Linux. This maximizes flexibility for users and the reproducibility of experiments. However, this also means that you should not use any OS-specific libraries or dlls in the backend. If an operation is not supported by the machine, you should raise a `NotImplementedError`. The actual process of implementing the methods varies widely from machine to machine. It is generally useful to search for firmware documents, search for log files generated by a manufacturer's software, or find other open source projects that have implemented the same machine. ## 3. Adding documentation (recommended) Find the relevant module in the `docs` directory. For example, the liquid handling backends module is located at `docs/pylabrobot.liquid_handling.backends.rst`. Then, add the name of the new backend to make sure that the new backend is automatically documented in the API reference. If you want, you can also add a new page to the `docs` directory that explains how to use the new backend. This is not required, but it is strongly recommended. Experience has shown that this is the best way to get people to actually use the new backend.
