# Contributing to Docs This document provides guidelines for contributing to the documentation. ## Images When you include images, use the `resize.py` script to resize them to a width of 720 pixels and save them as compressed JPEGs. This ensures that images are optimized for web use. This helps reduce page load times and reduce total repo size. ```python from PIL import Image import sys import os def resize_image(input_path, output_path=None, width=720, quality=80): """ Resize an image to the specified width while maintaining aspect ratio, then save it as a compressed JPEG for web use. """ img = Image.open(input_path) if img.width > width: w_percent = width / float(img.width) height = int(img.height * w_percent) img = img.resize((width, height), Image.LANCZOS) print(f"Resized down to {width}x{height}") else: print(f"Skipping resize: image width ({img.width}px) <= target width ({width}px)") if img.mode in ("RGBA", "P"): img = img.convert("RGB") if output_path is None: base, _ = os.path.splitext(input_path) output_path = f"{base}_resized.jpg" img.save(output_path, "JPEG", quality=quality, optimize=True) print(f"Saved: {output_path} (quality={quality}%)") if __name__ == "__main__": if len(sys.argv) < 2: print("Usage: python resize.py [output_path]") sys.exit(1) inp = sys.argv[1] outp = sys.argv[2] if len(sys.argv) > 2 else None resize_image(inp, outp) ``` You can easily resize images in bulk using a bash script: ```bash for img in *.png *.jpg; do python resize.py "$img" done ```
