# The device registry Every machine listed on the {doc}`/user_guide/machines` page comes from a single JSON file, `docs/_static/devices.json`. Two directives read it: `device-table` renders a searchable table of devices, `device-card` renders a single device as a card. Adding a machine to the docs means adding one object to that file. ## Adding a device Append an object to `docs/_static/devices.json`: ```json { "id": "cole-parmer-masterflex", "vendor": "Cole Parmer", "name": "Masterflex L/S", "models": [ {"name": "07522-20", "status": "full"}, {"name": "07522-30", "status": "full"}, {"name": "07551-20", "status": "full"}, {"name": "07551-30", "status": "full"}, {"name": "07575-30", "status": "full"}, {"name": "07575-40", "status": "full"} ], "kind": "pump", "capabilities": ["pumping"], "status": "full", "api": "pylabrobot.cole_parmer.Masterflex", "api_version": "v1", "code_slug": "cole_parmer", "manager": "https://discuss.pylabrobot.org/u/rickwierenga", "oem": "https://corporate.avantorsciences.com/us/en/bioprocess-solutions/fluid-management/masterflex-peristaltic-pumps/ls-series" } ``` | Field | Required | Meaning | |---|---|---| | `id` | yes | Unique kebab-case identifier. Used by `device-card` and as the HTML anchor (`#device-`). | | `vendor` | yes | Manufacturer, as users would search for it. | | `name` | yes | Display name for the device or device family, without the vendor. | | `models` | no | Model objects when one entry covers several models. `name` is required; `status` may be `wip`, `basic`, `mostly`, or `full` and defaults to the device status when omitted. Models render as searchable sub-rows with their support status beneath the device. | | `kind` | yes | Device type, e.g. `plate reader`, `sealer`, `arm`. Must be one of `KINDS` in `docs/_exts/plr_devices/data.py`. | | `status` | yes | One of `wip`, `basic`, `mostly`, `full`. See {doc}`/user_guide/machines` for what each level means. | | `needs_hardware_testing` | no | Boolean, default `false`. Set `true` when hardware testing is needed, based on the device's docs, driver warnings, or reports. Each model can also set this boolean; omitted model flags inherit the device flag. | | `capabilities` | no | Core functions, e.g. `["heating", "shaking"]`. Must come from `CAPABILITIES` in `docs/_exts/plr_devices/data.py`. These drive the badges and the capability filter. | | `api` | no | Import path of the driver class, e.g. `pylabrobot.curiox.CurioxHT2000`. | | `api_version` | no | `v1`, or `v0` for drivers still under `pylabrobot.legacy`. | | `doc_slug` | no | The machine's own page, relative to `docs/user_guide/` and without the extension. Links the device name and builds the **docs** link; verified at build time. | | `code_slug` | no | The driver's module or package, relative to `pylabrobot/`. Builds the **code** link to the source on GitHub; verified at build time. | | `manager` | no | Forum profile of whoever looks after this driver, e.g. `https://discuss.pylabrobot.org/u/rickwierenga`. Shown as their handle, and who to ask about the device. | | `oem` | no | Manufacturer product page. | | `notes` | no | One line of additional context about the entry, such as functionality that is missing. Use `models` for the hardware models an entry covers. | The registry is validated when the docs build starts: unknown fields, duplicate ids and unknown statuses fail the build, as do `doc_slug` and `code_slug` values that do not point at a real page or a real module. `kind` and `capabilities` are controlled vocabularies, listed as `KINDS` and `CAPABILITIES` in `docs/_exts/plr_devices/data.py`. A machine that needs a genuinely new term gets it added there in the same change — the point is that "sealer" and "heat sealer" cannot quietly become two different filter chips. Terms that nothing uses are removed, and a test enforces both directions. The two slugs exist so entries stay short and the prefixes stay in one place. `doc_slug` is resolved against `plr_devices_doc_prefix`, and `code_slug` against `plr_devices_code_root` and the repository and branch in `html_context` — the same ones the theme's "edit this page" links use. ### Adding a guide to an existing device If a device already has a registry object, update that object rather than appending another one: 1. Set `doc_slug` to the guide's path relative to `docs/user_guide/`, without `.md` or `.ipynb`. 2. Add the guide to its manufacturer's `{toctree}`. 3. Put a `{device-card}` directive in the guide using the registry object's `id`. For example, a notebook at `docs/user_guide/agilent/vspin/hello-world.ipynb` uses: ```json "doc_slug": "agilent/vspin/hello-world" ``` and its card is: ````md ```{device-card} agilent-vspin ``` ```` Validate registry changes with: ```bash python -m pytest docs/_exts/plr_devices/registry_tests.py ``` ## Rendering a table A bare `device-table` renders every device, with a search box, a **Show models** toggle and filter chips. Models render as sub-rows beneath their device. A device row can reveal its own models, and the toggle reveals them all. Each model's support badge is aligned beneath the device support column. Models are initially hidden, but a text search always matches them and automatically reveals matching model rows when 10 or fewer devices remain: ````md ```{device-table} ``` ```` Options narrow it down: ````md ```{device-table} :vendor: QInstruments :search: false :filters: false ``` ```` `capabilities`, `vendor`, `kind` and `status` each take one value and filter the rows. `search` and `filters` take `false` to hide the search box or the chips, which is useful for a short, pre-filtered list on a vendor page. The {doc}`/user_guide/needs-testing` page uses: ````md ```{device-table} :needs-hardware-testing: ``` ```` This includes devices that need hardware testing and families with at least one model that needs it. Only flagged models appear in this table; other tables and cards keep the complete model list. An explicit model flag overrides the device default. For example, a family can have `"needs_hardware_testing": true` with `"needs_hardware_testing": false` on its tested model. A family whose models are all explicitly `false` is excluded. An omitted or `false` flag means there is no testing request recorded, not a claim that all firmware or operations are verified. Use existing docs, code warnings, or linked hardware reports to set the flag; do not infer it from `wip` or any other support level. A device or model awaiting initial hardware verification has `status: "wip"`, even if its shared driver works on other models. After reviewing a hardware report, update only the tested model or device, preserve flags for untested siblings, and link the evidence in the device guide. Follow the reporting and follow-up process on {doc}`/user_guide/needs-testing`. ## Rendering a card `device-card` renders one device. It works anywhere MyST is parsed, including markdown cells in the notebooks under `docs/user_guide` — put one at the top of a machine's hello-world notebook so the page carries the same vendor, models, support level, capabilities and links as the table. Models appear in a scrollable table with a colored support badge for each model. The table's height is capped so long model lists keep the card compact. When a model has no explicit status, its badge uses the device's support level. ````md ```{device-card} curiox-ht2000 ``` ```` A directive is rendered when Sphinx builds the docs. In a notebook opened in an editor it shows as a literal code block instead, so a card on a notebook page only appears on the published version. ## Styling The markup is generated by `docs/_exts/plr_devices`, and styled by `docs/_static/plr_devices.css`. Search and filtering are handled by `docs/_static/plr_devices.js`. Capability badge colors are derived from a hash of the capability name, so a new capability gets a stable color without a CSS change.
