# Devices that need testing Have access to one of these devices? Run your device's PyLabRobot hello-world example and report what works and what fails. Reports of successful runs, partial success, and failures are all useful; you do not need to write a driver or open a pull request to contribute. ## Needs testing This table lists devices and models flagged as needing hardware testing based on their existing documentation and driver warnings. **Support** applies to the listed device or model. A shared driver may support one model while another still needs hardware testing. Models awaiting initial hardware verification are marked **WIP**. Use **Show models**, expand a device row, or search for your exact model. Only models that need testing appear here. Follow **docs** for the guide and known limitations, **code** for the driver, or **Manager** to find the person looking after it. Some entries still need implementation work; check their guide before attempting a run. ```{device-table} :needs-hardware-testing: ``` ## Test and report 1. Choose your exact model and read its guide, including setup instructions and known limitations. If you need help, the listed manager is available on the [forum](https://discuss.pylabrobot.org). 2. Record the model, firmware, connection settings, and PyLabRobot version or Git commit (`git rev-parse HEAD` from your checkout). Start with the guide's hello-world example and test only the operations appropriate for your hardware and setup. 3. Record each operation you tried, its expected result, and what actually happened on the instrument. A command returning without an error is not enough to confirm the physical result. Include the script or notebook, output, and relevant I/O logs. Mark steps you did not run as **Not tested**; simulation and mock tests do not count as hardware verification. 4. [Submit a device test report](https://github.com/PyLabRobot/pylabrobot/issues/new?template=device-test-report.md). Use **Works**, **Partly works**, or **Does not work** in the title and fill in the template. Search existing issues first; if there is a report for the same model and problem, add your results there. You can also post the same details on the [forum](https://discuss.pylabrobot.org) and link any related issue or pull request. For example, if connection and status queries work but plate retrieval fails, report **Partly works**, with separate rows for each operation. If setup fails, report **Does not work**, include the error, and mark later steps as **Not tested**. Successful reports should also include the code and observed results so someone else can reproduce them. ## What happens to a report The device manager or a maintainer reviews the evidence and follows up on missing details or failures. A report applies to the model, firmware, and operations you actually tested; it does not verify every model in a family. Once the relevant hardware checks pass, a contributor or maintainer can open a pull request to set `needs_hardware_testing` to `false` for that device or model in the {doc}`/contributor_guide/device-registry`, link the report in the device's guide, and update any not-tested warnings in the guide and driver to match the verified scope. Keep the flag set when testing remains incomplete or a failure still needs a fix and another hardware run. Update the tested device or model's support level to reflect its verified capabilities.
