Operator actions#
ManualOperator lets a protocol await work performed by a person without coupling the protocol
to a terminal, notebook, graphical interface, or external task system.
Why use a manual operator?#
Many protocols start with a direct input() call. That is a reasonable choice for a simple
notebook pause, but ManualOperator gives the same physical handoff a reusable PLR contract:
Provider independence: keep the protocol code unchanged while presenting the request through terminal input, a notebook, a custom GUI, LIMS, Slack, or another acknowledgement system.
Explicit outcomes: providers report
completed,cancelled, orfailedrather than reducing every acknowledgement to Enter being pressed.Resource-model reconciliation:
move_resource()validates a manual transfer before and after acknowledgement, then applies the corresponding PLR assignment only when the model is still consistent.Native traceability: an active EventBus receives a correlated lifecycle with the action, affected resources, endpoints, operator acknowledgement, and failure details where applicable.
The built-in console provider is intentionally simple. It is a practical default for users who only need an interactive pause; more capable providers are optional application integrations.
from pylabrobot.manual_operator import ConsoleOperatorActionProvider, ManualOperator
operator = ManualOperator(ConsoleOperatorActionProvider(), name="cell_operator")
await operator.perform(
action="centrifuge.spin",
title="Spin sample plate",
instructions="Spin plate_1 at 300 x g for 180 seconds, then return it to the handover nest.",
details={
"relative_centrifugal_force": 300,
"duration": 180,
The built-in console provider treats Enter as a successful acknowledgement. Applications can
implement OperatorActionProvider to present the same request through a graphical interface,
HTTP service, LIMS, or message broker:
from pylabrobot.manual_operator import OperatorActionRequest, OperatorActionResult
class DashboardOperatorActionProvider:
async def request(self, action: OperatorActionRequest) -> OperatorActionResult:
result = await dashboard.publish_and_wait(action)
return OperatorActionResult.completed(confirmed_by=result.user)
OperatorActionRequest carries any direct modeled resources plus optional source and
destination endpoints. Providers that cross a process boundary can serialize those objects in
their own transport format; details remains for operation-specific request data.
For a complete notebook example using a chatterbox incubator, manual plate transfer, plate reader, and optional EventBus subscriber, see the ManualOperator Jupyter cookbook.
Providers return one of three explicit outcomes:
completed:perform()returns the result and the protocol continues.cancelled:perform()raisesOperatorActionCancelledError.failed:perform()raisesOperatorActionFailedError.
An acknowledgement records what the operator reported. It does not prove that the physical work
occurred. Protocol-specific validation and resource-model reconciliation should happen before or
after perform() as appropriate.
Moving a resource#
Use move_resource() when the manual action transfers a modeled PLR resource between two modeled
locations:
from pylabrobot.resources import Rotation
await operator.move_resource(
resource=sample_plate,
source=centrifuge_loader,
destination=handover_nest,
destination_rotation=Rotation(z=0),
The method validates the source and destination before prompting, but leaves the resource assigned
to its source while the operator works. After the provider reports completion, it validates the
model again, detaches the resource from its source, and assigns it to the destination using PLR’s
normal resource-assignment machinery. This supports transfers between holders on the same deck
root. A ResourceHolder supplies its normal child location; other destinations can use an
explicit destination_location=Coordinate(...). Pass an explicit
destination_rotation=Rotation(...) when the manual move changes orientation. The rotation is
never inferred from the destination holder and is applied before a holder calculates its child
location. If final assignment fails, the original parent, location, and rotation are restored.
destination_rotation is the resource’s local rotation relative to destination, not an
absolute/world rotation. After assignment, the resource’s absolute rotation is composed from the
destination’s absolute rotation and this local rotation. For a manual move that replaces an
automated transfer, pass the destination-local pose that the automated transfer would produce; do
not copy the source resource’s local rotation unless that is physically correct for the
destination.
Cancellation, reported failure, and provider exceptions do not modify the resource model. If the model changes while the operator request is pending, the method raises an error rather than overwriting the newer state.
EventBus integration#
When an EventBus subscriber is active, each awaited action emits one correlated lifecycle using the requested action as its semantic subtype:
manual_operator.centrifuge.spin.started
manual_operator.centrifuge.spin.completed
The event identifies the ManualOperator as device, includes any direct PLR resources passed
to perform(), and preserves the request’s title, instructions, confirmation text, and structured
details. The completed event adds confirmed_by and the provider’s result message when supplied.
Cancellation, reported failure, invalid provider results, and provider exceptions emit .failed
with the normal EventBus error fields.
Use stable action identifiers such as centrifuge.spin, plate_reader.read, or
quality_control.inspect. When the manual action has an automated counterpart, use that
operation’s canonical field names and PLR default units inside details. move_resource() emits
manual_operator.resource.move.* with the direct moved resource plus its true source and
destination resource references; do not mirror those endpoints as free-form details. The normal
resource.unassigned and resource.assigned state-transition events record the subsequent model
update.
