Y-probing#
With PyLabRobot, you can probe the y position of any object on a STAR(let) deck. See also z probing for doing the same in the z direction.
Warning
This example uses the teaching tips. These are metal tips that are not forgiving. Be particularly careful when moving the channels around to avoid collisions.
Example setup#
from pylabrobot.liquid_handling import LiquidHandler, STARBackend
from pylabrobot.resources import STARDeck # or STARletDeck
star = STARBackend()
lh = LiquidHandler(backend=star, deck=STARDeck())
Capacitive y-probing using cLLD#
If you are mapping a capacitive surface, you can use the cLLD sensor to detect the surface.
Warning
teaching_tip = lh.deck.get_resource("teaching_tip_rack")["A1"]
await lh.pick_up_tips(teaching_tip)
await star.prepare_for_manual_channel_operation(0)
# TODO: change this to a position that works for you
await star.move_channel_x(0, 500)
await star.move_channel_y(0, 300)
Use STARBackend.clld_probe_y_position_using_channel to probe the y-position of a single point at the current xz plane. This function will slowly move the channel until the liquid level sensor detects a change in capacitance. The y-point of the point of the tip is then returned.
await star.clld_probe_y_position_using_channel(
channel_idx=0,
probing_direction="forward",
channel_idx=0,
probing_direction="backward",
await lh.return_tips()
