Liquid level detection on Hamilton STAR(let)#
Liquid level detection (LLD) is a feature that allows the Hamilton STAR(let) to move the pipetting tip down slowly until a liquid is found using either a) the pressure sensor, or b) a change in capacitance, or c) both. This feature is useful if you want to aspirate or dispense at a distance relative to the liquid surface, but you don’t know the exact height of the liquid in the container.
To use LLD, you need to specify the LLD mode when calling the aspirate or dispense methods. Here is how you can use pressure or capacative LLD with the aspirate :
await lh.aspirate([tube], vols=[300], lld_mode=[STARBackend.LLDMode.GAMMA])
The lld_mode parameter can be one of the following:
STARBackend.LLDMode.OFF: default, no LLDSTARBackend.LLDMode.GAMMA: capacative LLD (cLLD)STARBackend.LLDMode.PRESSURE: pressure LLD (pLLD)STARBackend.LLDMode.DUAL: both capacative and pressure LLDSTARBackend.LLDMode.Z_TOUCH_OFF: find the bottom of the container
The lld_mode parameter is a list, so you can specify a different LLD mode for each channel.
Note
The lld_mode parameter is only available when using the STAR backend.
Going into or out of the liquid#
You can use the immersion_depth backend kwarg to move the tip with respect to the found liquid surface. A positive value means to go deeper into the liquid, a negative value means to go above the liquid.
Going 1mm below the liquid for aspiration:
await lh.aspirate(
[tube],
vols=[300],
lld_mode=[STARBackend.LLDMode.GAMMA],
immersion_depth=[1])
Going 1mm above the liquid for dispens:
await lh.dispense(
[tube],
vols=[300],
immersion_depth=[-1])
Moving with liquid surface (liquid following)#
Through another backend kwarg, surface_following_distance, you can move with the liquid:
await lh.aspirate(
[tube],
vols=[300],
surface_following_distance=[10], # 10mm
Catching errors#
All channelized pipetting operations raise a ChannelizedError exception when an error occurs, so that we can have specific error handling for each channel.
When no liquid is found in the container, the channel will have a TooLittleLiquidError error. This is useful for detecting that your container is empty.
You can catch the error like this:
from pylabrobot.liquid_handling.errors import ChannelizedError
from pylabrobot.resources.errors import TooLittleLiquidError
channel = 0
try:
await lh.aspirate([tube], vols=[300], lld_mode=[STARBackend.LLDMode.GAMMA], use_channels=[channel])
except ChannelizedError as e:
if isinstance(e.errors[channel], TooLittleLiquidError):
print("Too little liquid in tube")
